6-spd and racing
Old Mar 29, 2004 | 06:01 PM
VICOUS's Avatar
VICOUS
Cruise-In II Veteran
Default 6-spd and racing
Hello
One of my friends has a 03 Z06 and wants to go drag racing with it. He plans on adding h/c and 3.90 gears. He wants to know how much rwhp can the stock rear end and tranny hold before braking. And what are you guys doing to make your 6-spd stronger at the track? In other words he knows that racing is a risk when you have 450 + rwhp, but what are you guys doing to make it all stay together.
:lurk:
Old Mar 29, 2004 | 06:18 PM
gonbad's Avatar
gonbad
Default Re: 6-spd and racing (VICOUS)
Transmission: Doesn't really like being powershifted to much. Upgrade the fluid to a good synthetic Redline or Amsoil. Crashed94 builds an upgraded MN12. Hardened Carbon Fiber synchros for 1-2 and a steel 3-4 shift fork are common upgrades. However the stock tranny seems to be very stout.
The big culprit is the rear diff and flex between the transmission and differential caused by high HP and using very sticky tires at launch. Have your friend contact DTE about their diffs and transmission/diff brace.
Old Mar 29, 2004 | 07:49 PM
Monster231's Avatar
Monster231
Default Re: 6-spd and racing (gonbad)
Transmissions are rated by torque not horsepower. the M12is a fairly strong trannie and can handle some serious Modding. Unles he is going to get into hardcore 1/4's with slicks and a rear end, he should be ok
Old Mar 30, 2004 | 08:27 AM
ToplessTexan's Avatar
ToplessTexan
Don't forget that Joe C broke his passenger side output shaft in his 3.73s on like their first or second pass with maybe headers and drag radials in his '01 ragtop. You already have enough power and torque to break stuff if you can hook hard.
If he was *really* your friend you'd suggest an A4 swap. :jester
Old Mar 30, 2004 | 10:55 AM
J-Rod's Avatar
J-Rod
Default Re: 6-spd and racing (ToplessTexan)
Drag radials tend to break more parts than Et Streets. I would a put a hardened shaft in the rear, and a gear and call it a day. Thats all we have in the car I am driving right now, and I launch it at 6600-6800. It makes 500RWHP, and so far looks pretty good.
Old Mar 30, 2004 | 04:19 PM
HP_Addict's Avatar
HP_Addict
Default Re: 6-spd and racing (J-Rod)
I have heard that drag radials break more parts than ET streets, but does this only refer to the 18" BF drag radials or is this common with all drag radials? A smaller diameter would appear to have more sidewall and more flex. ET streets are 16". So is a 16" drag radial comparable to a 16 "ET street.
Just curious
Chris
Old Mar 30, 2004 | 04:53 PM
CDH76's Avatar
CDH76
Default Re: 6-spd and racing (marlowchris)
I was speaking with someone at Lingenfelter and he said the stock Z06 tranny is very strong. I was going to get a supercharger on my car before I decided to be smart and get a house. :smash: He said the only thing I would need to upgrade was my clutch.
Old Mar 30, 2004 | 11:04 PM
wht2000vette's Avatar
wht2000vette
There is a special bracket that is made for that. RPM sells them and I have seen them prove there worth on more then one car. :thumbs:
Old Mar 30, 2004 | 11:56 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: 6-spd and racing (wht2000vette)
:iagree:
Old Mar 31, 2004 | 03:13 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:iagree: :cheers:
To 6-spd and racing
