Biggest MAF
Old Mar 29, 2004 | 07:20 PM
ITSovr4U's Avatar
ITSovr4U
Default Biggest MAF
My question is who sells the biggest MAF. And how much. I have the LSX 90mm intake and TPIS 90MM TB. It will be going on my 408. I currently have the 80mm Granetelli but feel it is not going to be good enough. Thanks, John :seeya
Old Mar 29, 2004 | 07:30 PM
goodhands's Avatar
goodhands
Default Re: Biggest MAF (ITSovr4U)
John, you may want to check into the Z06 MAF. Stock, it has no screen and is 85mm. You may also be able to use the MAF tables to reprogram your PCM. Not sure if it is the largest out there though? :yesnod:
Old Mar 29, 2004 | 07:32 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Biggest MAF (goodhands)
I think all MAF from 2001+ are 85mm
To Biggest MAF
