turn signal problem.....
Old Mar 30, 2004 | 09:08 AM
jamesge's Avatar
jamesge
Default turn signal problem.....
Bulbs are fine. All rear lights work fine.
Put key in and turn to on position, DRL's not on but all four front orange bulbs come on as if the headlights switch is on, rear lights are off (with key on and headlights switch off, only the two DRL's should be on, not the two front sidemarkers). Use turn signal, left or right and they flash rapidly. Put headlights down and dash lights flicker three/four times. Turn hazard switch on, fog lights also flash. Pulled the DRL relays and all problems, except front turn signals, went away (of course all front orange bulbs are out with the relays pulled).
Could these relays be bad? Is the hazard switch to blame?
[Modified by jamesge, 2:11 PM 3/30/2004]
Old Mar 30, 2004 | 07:17 PM
Mel 2001's Avatar
Mel 2001
Default Re: turn signal problem..... (jamesge)
Hurry check to see if your battery is leaking! :leaving:
