just got back from first drive with dynojet wideband a/f system. works great!!!..reads very fast :thumbs: had my ltft's looking pretty good and was waiting for this so i could do wide open throttle tuning... my part throttle a/f is right at 14.7 .....wide open was 11.2 to 11.5.... a little bit rich...just did some tuning with ls1 edit to my programing...gonna flash pcm later and see what changes it makes. :
this sure looks like a way cool way to do real world tuning :thumbs:
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Re: just installed dynojet wideband!! (mike@xtreme)
I have LS1 Edit and was going to buy this wideband setup. My question is what tables to you change to adjust your A/F ratio? What would you say is the ideal WOT ratio? :cheers:
Re: just installed dynojet wideband!! (Crazy C5 Cowboy)
wot ratios will vary with application....good goal is for a/f at wot about 12.6 to 12.9..... use the pe/ rpm table for wot adjustments.... as for part throttle there are different ways to change the afr...maf translation table...ifr table...check out this sight.....http://ls1edit.slowcar.net/faq.html... :thumbs: :auto:
Re: just installed dynojet wideband!! (vettemaster1)
couple of quick flashes and the wot afr is at 12.5...... some more tuning and driving and should soon be ready for dyno... cant wait to see results of mods!!! :) :auto:
Have to add this to my future mods list.
