Oil pressures sensor question..
Old Mar 30, 2004 | 04:28 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Oil pressures sensor question..
It looks like the oil pressure sensor on my '98 Vert stopped working. It shows 127 psi even when the car is shut off...
Where is the oil pressure sensor and how do I change it.. I have changed a oil pressure sensor before on a C4.. but never on a C5...
Any help is appreciated!!
Old Mar 30, 2004 | 04:34 PM
TXNC5's Avatar
TXNC5
Default Re: Oil pressures sensor question.. (GrandSportC3)
If memory serves me correctly, I believe it is on top of the block near the firewall on the driver's side. I will see if I can confirm with a picture.
Old Mar 30, 2004 | 04:36 PM
TXNC5's Avatar
TXNC5
Look here: https://www.corvetteforum.com/techti...=246&TopicID=1
and here
http://forums.corvetteforum.com/zero...583#1546175583
Old Mar 30, 2004 | 04:39 PM
GrandSportC3
Default Re: Oil pressures sensor question.. (TXNC5)
Thanks!! Appreciate it!!
To Oil pressures sensor question..
