HELP C5 Newbie here!
Old Mar 31, 2004 | 05:24 PM
Dilligas's Avatar
Dilligas
Default HELP C5 Newbie here!
I received my Blackwing today and want to install it but I have already run into a snag. Can anyone tell me how to get the plug loose from the MAF? I don't want to force it but I cannot figure this out. :banghead: Thanks in advance :cheers:
Old Mar 31, 2004 | 06:29 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: HELP C5 Newbie here! (Dilligas)
I hope this helps as I remember having the same problem a couple years ago doing my "first" mod....on the passenger side of the gang plug is a small clip type thingy :D inseert a small screw driver blade under that and it frees the plug....good luck
Old Mar 31, 2004 | 07:01 PM
James G's Avatar
James G
The white clip on top of the plug is not what your looking for. The clip that will release the plug is in in front, on the nose side. Get a small screw driver between the housing and the clip and release it from the catch. Don't pull on the wires, you will need to get the screwdriver between the housing and the plug and work it out.
Old Mar 31, 2004 | 07:12 PM
Dilligas's Avatar
Dilligas
Default Re: HELP C5 Newbie here! (James G)
Thanks, I will try that. The engine compartment on this car is a lot different than my C4 :eek:
To HELP C5 Newbie here!
