Steering Wheel Position Sensor
Old Apr 1, 2004 | 12:40 PM
Easygeezer's Avatar
Easygeezer
7th Gear
Default Steering Wheel Position Sensor
I have a fault code on my 1997 C5 which has been on there since new, it is asking for a new Steering Wheel Position Sensor, does anyone know what it does / how important it is to replace it and if the fitting of a new one if required is a difficult job
Many thanks
Andy
Old Apr 1, 2004 | 12:44 PM
BHP's Avatar
BHP
Default Re: Steering Wheel Position Sensor (Easygeezer)
Common problem plus you will need a PCM update. It is located at the base of the steering column. Time to visit dealer.
[Modified by BHP, 11:40 AM 4/1/2004]
Old Apr 1, 2004 | 01:13 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The steering position sensor works in conjuction with the ABS and Active Handling,if equipped...Requires removing the steering column to replace :yesnod:
Old Apr 1, 2004 | 01:22 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Steering Wheel Position Sensor (C-5 TECH)
________________________________________ ________________________
:iagree: I had mine replaced a couple of years ago. I believe it was over $300.00 back then :sad:
Old Apr 1, 2004 | 02:22 PM
mikeyc6's Avatar
mikeyc6
Default Re: Steering Wheel Position Sensor (vette#one)
I replaced mine on my 99 a while back and took the time to do pics and procedures. Here they are:
http://www.ddisoftware.com/c5-procs/
Not really as bad as it looks. :smash:
Mike
Old Apr 2, 2004 | 08:20 AM
Easygeezer's Avatar
Easygeezer
7th Gear
Thanks for all your help, it explains what I needed to know
To Steering Wheel Position Sensor
