MAF Housing- worth it or not?
Old Apr 2, 2004 | 07:00 AM
mowrey96's Avatar
mowrey96
Default MAF Housing- worth it or not?
Does anyone have this mod? It appears to be the housing, not the actual MAF sensor, so it would not requir any re-programming. I had trouble with a Granatelli MAF Sensor in the past and do not want another problem. Please give some feedback. Here is the listing at MADIRECT.COM.
High performance 1994-00 Mass Air Flow Housing gulps over 1000 CFM(stock units flow only 644 CFM)
. Nylon Composite hold less heat, provides cooler, denser air charge
. Includes o-ring seal set built-in air foil for smoother air flow
. Up to 9hp and 7 ft/lbs torque gain
. Works well with low restriction air cleaners & exhaust upgrades
Tests have proven that the quickest C4 horsepower gains are found when you improve your engine's ability to "breath". That's just what the High Performance Mass Air Flow Housing does. Larger diameter housing provides a 55% increase in available air flow. Nylon construction provides cooler, denser air for more horsepower and more efficient fuel use. Housing mounts directly to your stock mass air flow sensor (MAF). No reprogramming necessary. Installs in less than one hour. Installation instructions included.
http://www.madvet.com/shop?frame=1.677
Old Apr 2, 2004 | 12:04 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: MAF Housing- worth it or not? (mowrey96)
Don't waste you $$$$ :nonod: :nono: :banghead:
Old Apr 2, 2004 | 12:07 PM
krabtree13's Avatar
krabtree13
Default Re: MAF Housing- worth it or not? (LittleBoyBlu99)
what he said!!! :steering:
Old Apr 2, 2004 | 01:06 PM
99blackFRC's Avatar
99blackFRC
complete waste of money.. don't bother :)
To MAF Housing- worth it or not?
