octane booster?
Old Apr 2, 2004 | 11:05 AM
vettemaster1's Avatar
vettemaster1
Default octane booster?
is anyone out there using octane booster, either home brew or store bought? if so what kind of results? :rolleyes:
i have been trying some home brew mixtures myself, mixed results... :crazy:
here are some chemicals that i was told increase octane
1. xylene
2.toulene
3.mtbe
4.methanol, ethanol
5. alcohol
has anyone used unleaded racing fuel as a booster to pump gas?
need to find economical means of raising octane........... help............ :steering:
[Modified by vettemaster1, 5:09 PM 4/2/2004]
Old Apr 2, 2004 | 11:25 AM
2ndVette's Avatar
2ndVette
Default Re: octane booster? (vettemaster1)
toulene is better but hard to find, Xylene is everywhere but it requires 2+ gallons per tankful and is cumbersome. I would recommend that you try Torco. I was a skeptic until I tried it and it works for me.
Old Apr 2, 2004 | 12:26 PM
Greg_E's Avatar
Greg_E
You can go to http://www.racegas.com and see if there are any gas stations near you selling Sunoco GT 100 (Also sold as CAM2 GT 100) at the pump. I was lucky enough to find a dealer near where I work. It doesn't come cheap though. I paid $5.79/gal.
Old Apr 2, 2004 | 08:41 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: octane booster? (2ndVette)
What is Torco? :confused: :D
Old Apr 2, 2004 | 09:20 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
This is the guy we buy Torco from... and it works!! http://www.jbsblownc5.com/html/torco.html
VR :cheers:
Old Apr 2, 2004 | 11:33 PM
boblackhardtop's Avatar
boblackhardtop
http://www.fbody.com/members/stevenm...ne_booster.htm
Old Apr 3, 2004 | 09:59 AM
James G's Avatar
James G
You may check at your local motorcycle shops, ones that support motocross.
In the Denver area I buy 114 at Vickery Yamaha for my race bike and I mix
it 50/50 in the car when I go to the mountains. :rofl:
Old Apr 3, 2004 | 11:29 AM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Re: octane booster? (Greg_E)
I would ask around the auto shops too. Some sell high octane gas around here but they dont advertise it.
Old Apr 4, 2004 | 04:53 AM
molon labe's Avatar
molon labe
most octane booster is a waste of money, and some of that crap can foul plugs. i just add a few gallons of race gas (110 octane low lead) that i get for $3.85/gal from the local truck stop, or i go out to the local airport (at night and when nobody is looking) and buy 120 octane aviation fuel from the runway pump (takes CC and costs $4/gal).
Old Apr 4, 2004 | 06:42 AM
te51cle's Avatar
te51cle
Default Re: octane booster? (tattooed)
Doesn't Avgas have lead in it ? If so it is only suitable if you have removed your cats.
Old Apr 4, 2004 | 10:16 AM
Slickk.'s Avatar
Slickk.
it's only 4.29 at the pump here
Old Apr 4, 2004 | 11:00 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Be careful with Xylene, I read here that one forum member used it when he dynod the car and found out the exhaust smell is overwhelming
Old Apr 4, 2004 | 12:20 PM
vetterdstr's Avatar
vetterdstr
The only time you need higher octane is if your car is heavily modified or if you are running the car VERY HARD on HOT DAYS. Other than that 92 or above should be just fine.
VR :cheers:
Old Apr 4, 2004 | 12:44 PM
lar66BB's Avatar
lar66BB
Default Re: octane booster? (vetterdstr)
:iagree:
The only time you need higher octane is if your car is pinging,
otherwise it doesn't do much.
Old Apr 4, 2004 | 01:30 PM
molon labe's Avatar
molon labe
Default Re: octane booster? (te51cle)
yes, and i removed my cats. :)
Old Apr 4, 2004 | 01:41 PM
'97 C5's Avatar
'97 C5
VR :cheers:
:iagree: Call Joel :iagree:
Old Apr 4, 2004 | 11:06 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: octane booster? ('97 C5)
:iagree: :iagree: TORCO...
Old Apr 4, 2004 | 11:43 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
VR :cheers:
:iagree: :yesnod:
Old Apr 5, 2004 | 02:25 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Default Re: octane booster? (Nitro-C5)
Thanks for the heads up guys!!
Yup, I got Torco, and it works!!!
Email me at kerijoel1@comcast.net if you need some.
JB
To octane booster?
