Question about A4 vent tube
Old Apr 3, 2004 | 08:55 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Question about A4 vent tube
I pulled my tranny and found this, what in the heck is the check valve for and why is it T'd in the line :confused:
Old Apr 3, 2004 | 10:03 AM
Analog Kid's Avatar
Analog Kid
Default Re: Question about A4 vent tube (runamuk)
Using my 02 manual I couldn't find a definitive statement that says what it is exactly for.
I did find a note in the removal/replacement procedure for the vent hose that says to "observe the orientation of the transmission vent hose check valve prior to removal of the hose."
Upon installation, "orient the transmission vent hose check valve as noted during prior to removal". Not much help I know.
Old Apr 3, 2004 | 11:46 AM
carpe dm's Avatar
carpe dm
To keep the yellow beer from flowing the wrong way...... :rolleyes: :D
Old Apr 4, 2004 | 08:17 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Question about A4 vent tube (carpe dm)
:lolg: :leaving: :lolg:
seriously though, if you put a check valve in a vent line wouldn't you think it should be inline with the vent :confused:
Old Apr 5, 2004 | 01:23 AM
BHP's Avatar
BHP
When I was working on my A4 I thought the check valve/vent was a little wierd. Just don't plug it off!
Old Apr 5, 2004 | 01:25 PM
corvettebob1's Avatar
corvettebob1
I bet if you look at the vent in the end of that line it's a Tabs valve.
What that is, is a 1 way valve that allows heated air to escape but it closes when it's drawn against to prevent water intrusion into the transmission.
What the part T'd into the line is, is a restricter to allow a slow return of cool air back into the transmission. :crazy:
Your axle vent is a Tabs valve also, I thought I had a pluged vent on my axle untill I blew some air into it and heard the valve unseat itself. :D
To Question about A4 vent tube
