Helpful hint when installing instrument gauge bezel
Old Apr 4, 2004 | 11:02 PM
jjk2509's Avatar
jjk2509
Default Helpful hint when installing instrument gauge bezel
I recently installed the chrome instrument gauge bezel and after I finished the tach would not work. I asked around and could not get any help on why it might not work. I decided to pull it apart again and see if I could figure out why it stopped working.
Well, I found out why and wanted to share this info with other so they do not have to tear the dash apart again because of a simple mistake.
When I pulled the gauges out of the car, I notice that the speedometer needle moved and the tach needle did not. I looked closer and noticed the tach needle was below the plastic resting pin and when I started the car the tach was working but it was located below the pin and could not move up because the pin was in the way.
I removed the clear plastic cover and put the needle on top of the pin and now it works great.
Hope this will help someone else.
:banghead: :banghead:
Old Apr 5, 2004 | 04:03 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Helpful hint when installing instrument gauge bezel (jjk2509)
I will watch needle and pin when I do the HUD in the next weeks.
Frederik
Old Apr 5, 2004 | 08:54 AM
jjk2509's Avatar
jjk2509
Default Re: Helpful hint when installing instrument gauge bezel (C5 Frederik)
Good Luck!!!
:flag
Old Apr 5, 2004 | 12:24 PM
carpe dm's Avatar
carpe dm
Thanks! :thumbs: :cheers:
To Helpful hint when installing instrument gauge bezel
