Raptor Shift light install, Wiring?
Old Apr 6, 2004 | 07:32 AM
ROJO99's Avatar
ROJO99
Default Raptor Shift light install, Wiring?
I have the Tack wire info, but does the power wire need to a hot all the time or can it be switched? Second where to ground?
Old Apr 6, 2004 | 09:02 AM
Cajun99's Avatar
Cajun99
Default Re: Raptor Shift light install, Wiring? (ROJO99)
I prefer this method for the tach wire vs. coming from the PCM to the passenger well
http://forums.corvetteforum.com/zerothread?id=619162
This should address your hot wire and ground...you do not want it "hot" all the time
http://www.zee-oh-six.com/install_pa...ht_install.htm
[Modified by Cajun75, 8:12 AM 4/6/2004]
