Need Help with fault codes
Apr 6, 2004 | 06:03 PM
Just finnished the assembly of my new Getrag 3:73 rear differential and TPIS longtube headers and Random race cats and took my baby for a short drive.
After 10 minutes I get P1870 alarm in the Powertrain Menu and that code is not on my list of explanations! ( a C after so it is a current alarm)
Also had an old H alarm in the Traction Control System menu, C1255 = EBTCM Internal Malfunction ?????????
Can someone also please explain what the hell that means?
Please help A.S.A.P if you have the answer.
Regards
Tommy
Apr 6, 2004 | 06:17 PM
Re: Need Help with fault codes (C5Sweden)
Transmission Component Slipping.
1st step in the flow is to check the tranny fluid.
Apr 7, 2004 | 12:55 AM
Re: Need Help with fault codes (Wt99C5)
Strange, changed the tranny fluid at the same time ?
Thanx for the answer!
Tommy
