service vehicle soon
Go here -- https://www.corvetteforum.com/techti...D=26&TopicID=1
This tells you how to get the stored codes from your PCM. Post your codes and someone will try to help. :chevy
found some codes, maybe one causing problem:
10-pcm-p1433h
28-tcs-c1255h
c1281h
99-hvac-b0361h
b0363h
b0441hc
:nonod:
10-pcm-p1433h
28-tcs-c1255h
c1281h
99-hvac-b0361h
b0363h
b0441hc
:nonod:
Here's another link to the code list.
1433 Is fuel sensor high voltage
C1255 EBTCM Internal malfunction
C1281 Steering Sensor Uncorrelated Malfunction
B0361 Left Actuator Feedback short to GND
B0363 Left Actuator Feedback Open
P0441 EVAP System No Flow During Purge -B
