PO441 EVAP System... No Flow During Purge?
Old Apr 6, 2004 | 08:57 PM
AtHomeSoda's Avatar
AtHomeSoda
Default PO441 EVAP System... No Flow During Purge?
OK... what does that code mean.. is it to do with the air conditioning? The Evaporator? help.... thanks :banghead: :skep: :grouphug: :auto: :hurray:
Old Apr 6, 2004 | 10:35 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: PO441 EVAP System... No Flow During Purge? (AtHomeSoda)
P0441 will set if you leave the gas cap loose or fill up with the vehicle running.The PCM monitors the pressure from evaporative emissions (fuel vapors) and a leak in the system causing vapors to go into the atmosphere will set this code :yesnod:
