CAGS install ( 6 spd ) / battery
Old Apr 6, 2004 | 09:31 PM
skip89's Avatar
skip89
Default CAGS install ( 6 spd ) / battery
Instructions with Mid Amer. CAGS says to disconnect the car battery. Did anyone actually disconnect the battery ? Also, if you did not, please tell me. Don't want to throw any codes...Thanks :chevy
Old Apr 6, 2004 | 10:01 PM
JAY KOCH's Avatar
JAY KOCH
Default Re: CAGS install ( 6 spd ) / battery (skip89)
NOPE, did Not disconnect battery for CAGS defeat or blackwing install. Good luck. :steering:
Old Apr 6, 2004 | 10:04 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: CAGS install (JAY KOCH)
It has been a while but I'm pretty sure I did disconnect the battery. I wouldn't think it is a big deal to leave it hooked up. They are just doing a CYA.
Old Apr 6, 2004 | 10:10 PM
DsC5's Avatar
DsC5
Can't hurt, so I disconnected mine.
Old Apr 7, 2004 | 12:19 AM
Richin Chicago's Avatar
Richin Chicago
Might as well play it safe but, I believe, the only time that circuit has voltage is when the CPU activates the solenoid and that is when the car is running and you are in first gear. I didn't disconnect my battery but, again it only takes 5 more minutes to play it safe.
To CAGS install ( 6 spd ) / battery
