A weird code---Check engine light & more
Old Apr 7, 2004 | 04:11 PM
Ellinaras's Avatar
Ellinaras
Default A weird code---Check engine light & more
What's up guys??
I was a little bored so here I am installing last weekend a TB bypass and a smooth air bridge between the TB and the air intake...
I start the car and Check engine light is ON (not flashing)
Of course I inspected all connections and wires and they were fine...
The next day I took it to my mechanic and he hooked it up on the computer and there is this code "High Air Intake Temperature Reading" (the words may not be excact)
Anybody has any ideas???? :confused: Was it the TB bypass????
Please help guys!!!!!!!!!!! :cheers:
[Modified by Ellinaras, 9:11 PM 4/7/2004]
Old Apr 7, 2004 | 05:17 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: A weird code---Check engine light & more (Ellinaras)
Don't waste good money having someone else pull codes for you when you can do it yourself, here are a couple of links and if the codes show an "H" after them just erase and try it again.
Getting DTC's
https://www.corvetteforum.com/techti...D=26&TopicID=1
Erasing DTC's
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Apr 7, 2004 | 05:25 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: A weird code---Check engine light & more (runamuk)
pull the code, and post here again. Someone here will tell you what it means.
Old Apr 7, 2004 | 06:08 PM
dpd's Avatar
dpd
if your fault is intake air temp high and you put a air bridge in and assuming your car is older,you had to swap the iat sensor from the old bridge to the new bridge[more than likely you had to drill a hole into the left side of the new air bridge].most likely it's missing or unplugged.if your car is late 02-up,the iat sensor is in the maf.
Old Apr 7, 2004 | 06:23 PM
Ellinaras's Avatar
Ellinaras
Default Re: A weird code---Check engine light & more (dpd)
Thanks for the responses so far.... :cheers:
My mechanic erased the Check Engine Light twice (free) but I looked at my codes anyway...here it is:::
5 errors in BO-RFA:
U1096 H
U1064 H
U1016 H
and:
C2100 H C
C2105 H C
According to the links provided above it seems that the first ones are old and the last ones are about Tire Pressure Sensors...Is that True???
I do not have the front tire sensors anymore for about a month. There was a message on the screen telling me about it but NO Check Engine Light until recently!!!!!
Moreover, when I checked for codes the Check Engine Light had not returned back on yet....Would that mean I would not be able to see it in the codes????
Any ideas guys???????? Thank you all :thumbs: :confused:
[Modified by Ellinaras, 11:40 PM 4/7/2004]
To A weird code---Check engine light & more
