what is code p1416?
Old Apr 8, 2004 | 04:56 PM
1fastmfc5's Avatar
1fastmfc5
Default what is code p1416?
code p1416 popped up last night on drive home. can anybody tell me what this means?
Old Apr 8, 2004 | 05:11 PM
C5X2C's Avatar
C5X2C
Default Re: what is code p1416? (1fastmfc5)
P1416 AIR System Bank 2
Check out - http://www.stengel.net/diccodes.htm
:flag
Old Apr 8, 2004 | 08:26 PM
tpocock's Avatar
tpocock
secondar air injection system right bank.
the air injection check valves tend to rust shut.
it is located behind the intake manifold.
The air injection pump turns on when the engine is first started to inject air into the exhaust to lower emissions until everything heats up.
If the pump is bad then you will get codes for both the right and the left.
Old Apr 9, 2004 | 07:20 AM
1fastmfc5's Avatar
1fastmfc5
Default Re: what is code p1416? (tpocock)
does this affect performance?
Old Apr 9, 2004 | 12:22 PM
tpocock's Avatar
tpocock
no, but you will fail a smog check.
To what is code p1416?
