Ported and coated oil pump GP
Old Apr 9, 2004 | 09:37 AM
Brian@ap-engineering's Avatar
Default Ported and coated oil pump GP
Hello,
We are having a GP on ported and coated oil pumps until april 14th.
These have oil shed coating on the outside and teflon coating inside on the gear and housing.
Price on the pump will be 125.00 plus shipping.
Pics here :http://community.webshots.com/album/120925102qntwZX
Thank you
Old Apr 9, 2004 | 09:38 AM
kumar75150's Avatar
kumar75150
Default Re: Ported and coated oil pump GP (Brian@ap-engineering)
I'm sorry but how is this better than the regular pump? Serious question. I have no idea. :)
From what I hear, the Z06 pump is usually good to 650rwhp or so.
Old Apr 9, 2004 | 04:32 PM
IFLUBYU's Avatar
IFLUBYU
Default Re: Ported and coated oil pump GP (kumar75150)
I'm sure this is as good or better, but I just put in Scoggin-Dickey's ported/blueprinted LS1 oilpump, and I am now running better oil pressure. Where I was running 40-42psi on the old pump, I am now running 50psi with the new. So call it a 20% increase. Gotta keep oil on all that upgraded valve train, booyah! With the teflon coatings on this one, I would expect less friction as the oil is pumped through, meaning quicker flow, less heat. I would also expect the life expectancy of the pump to be increased.
Not an expert, just my $.02
Hope that helps. :thumbs:
Old Apr 9, 2004 | 05:04 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
:lurk:
Old Apr 9, 2004 | 07:21 PM
ShadowZ28's Avatar
ShadowZ28
Default Re: Ported and coated oil pump GP (Umrswimr)
Will these work on an F-Body?
Joe
Old Apr 10, 2004 | 07:42 PM
98 Pace's Avatar
98 Pace
Default Re: Ported and coated oil pump GP (ShadowZ28)
Yes they will work on an F-Body. I run one on mine. If you think about it, any opportunity to reduce drag coefficient in a pump or gear related mechanism will increase durability and efficiency.
Tom
To Ported and coated oil pump GP
