Rear wheel bearings, etc?
Old Apr 9, 2004 | 03:34 PM
385-C5's Avatar
385-C5
Default Rear wheel bearings, etc?
So, I went to the stealership for an inspection and of course they found things wrong. Anyway, they said I need new rear wheel bearings, and my axle seal is leaking. They want to charge me about 2 g's? They said the bearings alone are $700 a piece. Is this something that most mechanics could do? Thanks
Old Apr 9, 2004 | 06:16 PM
Z11409's Avatar
Z11409
Default Re: Rear wheel bearings, etc? (385-C5)
Same Timken brand bearing is avaiable at AutoZone for under $200 each.Its simple nut and bolt replacement-.
Golden Rule #! If the box says "Corvette " on it--Your paying too much for it.
Old Apr 9, 2004 | 07:49 PM
385-C5's Avatar
385-C5
Default Re: Rear wheel bearings, etc? (Z11409)
:iagree:
Thanks. I did a search and found some good info. Let me think $700 for the GM part or $127 at autozone. That's a tough one.
Old Apr 10, 2004 | 01:46 AM
MacC5's Avatar
MacC5
:iagree:
Don't do it!!! I juuuust got 2 rear wheel bearings on my 99 because my speed sensors were rubbing on the inside & excessive slop in the wheel. I paid less than $400 for both. Paid my local Vette mech another $200 to put them on.
Old Apr 12, 2004 | 05:16 PM
385-C5's Avatar
385-C5
Default Re: Rear wheel bearings, etc? (MacC5)
I bought 2 OEM rear wheel bearings from NAPA for $500 and a lifetime warranty. Thats quite a bit better than $1400.
To Rear wheel bearings, etc?
