Adding cam-- later add headers....
Old Apr 9, 2004 | 08:45 PM
1999PewterCorvette's Avatar
1999PewterCorvette
Default Adding cam-- later add headers....
Ok guys-- All this talk about swapping cams got me fired up and I bought one and am having it installed this week. Then Im having my car dyno-tuned 2 weeks later. I know its optimal to have LT headers with the cam but money is tight with cam, springs, pushrods, install, and tuning. So heres my question. Once I have the cam installed and the car dyno-tuned, If I add some Long-tube headers later, am I gonna have to have it tuned again??? Will the LT headers disrupt my previous LS-1 edit enough to where I should have it tuned a second time??--- I hope not (more and more money)
Rob
Old Apr 9, 2004 | 08:48 PM
1999PewterCorvette
Default Re: Adding cam-- later add headers.... (1999PewterCorvette)
BTW, I want to personally thank the forum for helping me choose my cam and giving me good info. I really would never have attempted a mod of this nature had it not been for all of you guys and sharing your knowledge and experiences. thanks again :seeya :seeya
Old Apr 9, 2004 | 08:50 PM
88sk's Avatar
88sk
like to know the same I got KOOKS system on & just ordered a 224 cam on mine.
Old Apr 10, 2004 | 12:04 AM
BlackMagicC5's Avatar
BlackMagicC5
Default Re: Adding cam-- later add headers.... (88sk)
Me three...... :lurk:
Old Apr 10, 2004 | 12:52 AM
SFVetteman's Avatar
SFVetteman
Adding the headers will probably lean it out a bit. How much I cannot really say. In any event I do not think it would make it dangerously lean. What you could do is to put it on the dyno that has a wideband O2, after you install the headers, and see what the air fuel ratio is and decide from there. Another option is to have it tuned a bit rich, say 12.7:1 and then when you install the headers you should be about right if the headers do indeed make it run a bit leaner.
Perhaps a call to Andy at A&A or maybe FLP or whatever tuner is familiar with the headers you will be installing would be a good idea, as they are more familiar with how the headers will affect the fuel mixture.
Old Apr 10, 2004 | 01:04 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Default Re: Adding cam-- later add headers.... (SFVetteman)
Nope, you won't have to retune, it is probably optimal to retune a little, but at most i see the gains being less than 5hp with the 2nd tune. I did my cam first and tuned the car, then added headers later, and the only the car needed was more room to run!!! Ran excellent with no second tune. :steering:
Old Apr 10, 2004 | 08:51 AM
1999PewterCorvette
Default Re: Adding cam-- later add headers.... (Mr. Big)
Thanks Mr. Big, thats what I wanted to hear.!! I know I wouldnt gain much in hp from a 2nd tune, I just didnt want to hurt the car by not tuning if I added headers later. Like mentioned above, I dont think it would change the car so much as to need a re-tune, maybe just lean it out a bit
So what kind of numbers did you see after the cam and tune and then after the addition of the headers???
Thanks, Rob
Old Apr 11, 2004 | 10:44 AM
1999PewterCorvette
Any guesses on what my horsepower will be BEFORE I add any headers to my car. ? Just have an MN6 with twin-flow air intake, mallett carbon fiber exhaust, Lunati 221 .558 cam and getting a dyno-tune with LS-1 edit. Anybody know any numbers I will be looking at???
Rob
Old Apr 11, 2004 | 11:06 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
That's not true in all cases.
Thanks, Rob
:skep: If you have it tuned with LS1 Edit" most tuners don't charge extra for retune. Different Headers can make much more than 5 hp gains over others. I would fine out from the tuner if he charges for upgrade tuning and if he does I would find one that don't. :yesnod: :thumbs:
gonbad's Avatar
gonbad
With the air intake and exhaust you are probably just over 300 rwhp now. So I would figure about 340-350 with the cam.
I adding a larger cam and pretty much have the same mods as you intake and exhaust and a friend of mine added a similiar cam with headers and cats and got 400 rwhp. I am hoping for about 365-375 with the stock manifolds and cats.
Old Apr 11, 2004 | 11:35 AM
1999PewterCorvette
Default Re: Adding cam-- later add headers.... (gonbad)
Im hoping to make 345 rwp with those mods.-- That will put me at 400-405 hp at the flywheel and thats my goal. Wanted to be close to the 02-04 Z06's.
Then later add some headers and I think I will be done. But thats never the case is it?? Who knew you could dump so much money on such a "ready to race" car right from the factory?
Rob
Old Apr 11, 2004 | 03:32 PM
Rays Vet's Avatar
Rays Vet
I have the same goals in mine.Hope you reach them.I did headers(kooks) first and doing cam next prabably the same cam as you.Do'nt forget to post results and a sound clip(I hear this is a mild cam) .And anybody that knows the specs. on the "stealth" cam and it's street manners chime in.
Rob
Old Apr 11, 2004 | 05:09 PM
Mr. Big's Avatar
Mr. Big
Default Re: Adding cam-- later add headers.... (Rays Vet)
Well i did dyno the car after the cam, this was with completely stock exhaust and ls1 intake, the only other mod i had was the blackwing. I had a 224/230 .561 .579 112 cam in the car, and she put down 341rwhp, after i added the full exhaust with tpis headers,x pipe and the ls6 intake, she hit the 380 range to the wheels.
I even did some wot runs and there was nothing to really tune, everything ran fine, i had access to tune again right away, just didn't need it. Big difference after the headers :smash:
[Modified by Mr. Big, 10:11 PM 4/11/2004]
Old Apr 11, 2004 | 07:12 PM
HITMAN99's Avatar
HITMAN99
In my experience, a 221 duration cam is not going to get you 45 HP w/ stock heads. It will be more like 30 HP. Also, the straight pattern grind will benefit more from the addition of LT headers than a split-duration grind. Every car is different though.
Most guys install headers at the same time as their cam to keep their install costs down.
Old Apr 12, 2004 | 01:15 PM
Mr. Jones's Avatar
Mr. Jones
Default Re: Adding cam-- later add headers.... (HITMAN99)
I just had my car tuned, 375rwhp & 382rwhp on a back to back run.
the higher number was after some cool down time. I have stock exhaust manifolds and cats with z06 cat-back. torque was low at 338rwq.
the straight pattern cam really needs the headers. I will be changing this setup. I asked about retuning after the header install, they said it would be minor. see profile for details
To Adding cam-- later add headers....
