When You Buy a Long Block Questions
Old Apr 10, 2004 | 10:10 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default When You Buy a Long Block Questions
I know the difference between a short block and a long block but as far as bolt ons I have a Question. Does it include the Oil pan and covers???
Old Apr 10, 2004 | 10:28 AM
Bill Reid's Avatar
Bill Reid
Default Re: When You Buy a Long Block Questions (Z06GMAN)
... not necessarily if you are buying outright... unless you specify. Some builders provide them standard (including elevated cost) and some don't to save you from having to buy something perhaps you don't need. But, if you take the core route and supply valvecovers, front/rear covers, and pan... you should get those back all cleaned up with new gaskets/seals... bolted up with a motor essentially ready to drop in.
:cheers:
Old Apr 10, 2004 | 10:48 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: When You Buy a Long Block Questions (Bill Reid)
Thanks Bill :cheers:
Old Apr 10, 2004 | 11:23 AM
Brian@ap-engineering's Avatar
Generally long blocks are minus the covers, unless the customer supplies them. Having the motor arrive to you with all of the covers on it is the best way to go. It's hassle free and you don't have to worry about anything getting in your engine. We prefer to ship engine all buttoned up. So if you can you may want to ship your covers or buy new ones so your engine builder can put them on for you. If youhave any questions please feel free to contact us.
Old Apr 10, 2004 | 11:44 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I don't know. Can you tell me the difference between a SB and a LB?
[Modified by ROCKnROLL, 11:45 AM 4/10/2004]
Old Apr 10, 2004 | 12:21 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: When You Buy a Long Block Questions (ROCKnROLL)
short block= block, crank, rods pistons, bearings, oil pump.
Long block = short block plus cam and heads complete
That's the quick response :cheers:
Old Apr 10, 2004 | 04:27 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Thanks...I was always too embarrassed to ask! :bb
Old Apr 10, 2004 | 07:56 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
from chevy yes on oil pan and valve cover just. no manifolds
To When You Buy a Long Block Questions
