"""HELP""" C5 mirror wiring schematic needed!!!!
Old Apr 11, 2004 | 01:07 PM
chillcat's Avatar
chillcat
Default """HELP""" C5 mirror wiring schematic needed!!!!
I'm hooking up c5 mirrors on my c4, and I just need to know which wire is which on the harness coming out of the side mirrors, Really all I might need to know is which is power and which is ground, don't want to take any chances---cause I believe there are 2 black wires on the c5 mirror and I don't know which one is power.....I know which is which on the c4 part....PLEASE HELP ME IF YOU CAN!!! thanks :p:
Old Apr 11, 2004 | 03:44 PM
markcz's Avatar
markcz
Default Re: """HELP""" C5 mirror wiring schematic needed!!!! (chillcat)
You have mail :cheers:
Old Apr 11, 2004 | 07:21 PM
chillcat's Avatar
chillcat
Default Re: """HELP""" C5 mirror wiring schematic needed!!!! (markcz)
Thanks alot...That should be all I need to know about wiring.... :cheers:
OH---SINCE you have access to the wiring diagrahms, I need to find out which wire is which under the dash in the front...if you don't mind, I have an 85 with 4+3 shift.....thankyou, Mostly I need to know, POWER, GROUND, IGNITION, TURN SIGNALS AND REAR BRAKE LIGHT, just the color of these wires..thankyou a BUNCH!!!
Old Apr 11, 2004 | 08:12 PM
markcz's Avatar
markcz
Glad I could help out with the C5 portion.
You may find what you're looking for in a Chilton or Haynes manual, otherwise I'd try posting in the C4 tech section, or just buy yourself a set of the C4 dealer Service Manuals. Check out eBay or HelmInc.com
Good luck! :seeya
To """HELP""" C5 mirror wiring schematic needed!!!!
