Comp 220/220 or 224/224?
Old Apr 12, 2004 | 06:53 PM
colbachlaw's Avatar
colbachlaw
Default Comp 220/220 or 224/224?
I have a comp 220/220 sitting in the box right now and I am beginning to think I might want to go with the comp 224/224 instead.
It is a daily driver with LG's and vararam and I am thinking about going with the AFR's if they live up to the hype.
I am currently running 12.4's @114 mph with 2.xx 60 ft times (stock tires). I am shooting for 11.9x et's.
I don't want to sacrifice much drivability, but I am going on a porsche club rally in late may and I want to be able to run with the twin turbo guys.
Thanks in advance for the advice.
Mike
Portland, OR
Old Apr 12, 2004 | 07:40 PM
Valdostavetteguy's Avatar
Valdostavetteguy
Default Re: Comp 220/220 or 224/224? (colbachlaw)
I have the Comp 224/224 .561/.561 and the drivability is great (I had Mike Norris tune it with LS1 Edit tho).
I'd recommend the 224 if u can work out a good trade for ur 220
Old Apr 12, 2004 | 07:59 PM
colbachlaw's Avatar
colbachlaw
Default Re: Comp 220/220 or 224/224? (Valdostavetteguy)
I bought my 220 at A&A and I can return it, so cost is not an issue.
I called A&A and was told that I would lose some bottom end with the 224 vs the 220. I don't want to give up too much bottom end, so I am having a tough time deciding. If I decide to get som AFRs later on, I am wondering if I will see enough gain to justify the $$ if I go with the 220 vs the 224.
I was pretty happy with my decision until I read a post on the Z06 forum talking about what a great daily driver cam the 224 is.
Thanks,
Mike
Old Apr 12, 2004 | 08:34 PM
2002Z06Yellow's Avatar
2002Z06Yellow
you will not be able to run with the turbos with a 224 cam... thats why i recommend the 220 cam... becuase you will not see any differnece in lope or driveability with the 220 cam...
Old Apr 12, 2004 | 08:50 PM
cliffkh's Avatar
cliffkh
Get the 224. If tuned, you will lose no driveability and it won't give up bottom end either. If you have an M6 especially, this is still very small cam by current standards - tuning has come a long way.
Old Apr 12, 2004 | 10:51 PM
JerriVette's Avatar
JerriVette
Default Re: Comp 220/220 or 224/224? (cliffkh)
Why couldn't a Z06 @ 3100 lbs and 400rwhp run with a Twin turbo Porsche?
Isn't 400rwhp like 470 flywheel hp..
3100/470hp 450tq = ?
versus a 3300lb twin turbo porsche with either 425hp or 450hp
3300/425 or 450 = ?
Hell. I'd venture to say a stock Z06 would give it a dam good run to Porsche TT, much less one with a few bolt ons and then a cam?
That said..I'd probably go for the 224/224 114lsa ...Isn't that considered a mild cam these days with the progression of ls1edit?
[Modified by JerriVette, 10:22 PM 4/12/2004]
Old Apr 12, 2004 | 11:07 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
I think the 224/.581 cam and the 205 AFR heads on a ZO6 would really compliment each other and be a :smash: killer street set up!:thumbs:
You would then be an excellent token Corvette :yesnod: on a Porsche rally and would represent US :cool: well with that set up, and show the :troll Frat boys :jester a surprise or two (acceleration+cornering)! :steering:
Good Luck,:boxing
Roy
Old Apr 12, 2004 | 11:15 PM
88sk's Avatar
88sk
Default Re: Comp 220/220 or 224/224? (7.0sc SuperVette)
I just ordered a 224/581 cam kit& was told by TSP I wouldnt notice any lowend loss,never heard anything bad about a 224 cam :nonod:
Old Apr 13, 2004 | 12:08 AM
colbachlaw's Avatar
colbachlaw
Default Re: Comp 220/220 or 224/224? (88sk)
Thanks for the advice guys.
I am now thinking about going with something bigger than the 224.
I am really impressed with the #'s AFR got with the 224/228 cam with their new heads.
I am open to suggestions if there are some other cams I should look at.
Thanks,
Mike
Old Apr 13, 2004 | 12:14 AM
MC TORCH RED's Avatar
MC TORCH RED
224/228 or 224 you can't beat the two :yesnod:
Old Apr 13, 2004 | 12:30 AM
2002Z06Yellow
Jerrivette
he will not run with the porsche for the following reasons:
1- he will not 400 RWHP with the setup he has.. 390 max
2- his torque curve is not as good as the porsche torque
3- the porsche has a very well power delivery system
4- a C5 is more like 3200
a Z06 will beat a C5 with bolt ons and a 224 cam..
a C5 needs to beat a Z06 to beat a 996 turbo.. i raced a turbo and a 224 cam only C5... the turbo will beat it!
i am just trying to make things clear for person who asked..
[Modified by 2002Z06Yellow, 5:33 AM 4/13/2004]
Old Apr 13, 2004 | 03:01 AM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Re: Comp 220/220 or 224/224? (2002Z06Yellow)
What kinda race? I've seen lot a of mid or high 11's posted in the qtr with a 224 and bolt ons... a stock Z06 isn't an 11 sec factory car is it?
Old Apr 13, 2004 | 04:19 AM
1fastmfc5's Avatar
1fastmfc5
Default Re: Comp 220/220 or 224/224? (99SilverC5Coupe)
i would recomend a larger cam than the 224. it idles well,no shake,never stalls. although this cam pulls hard, you will want to pull harder. maybe a 228 or 230?
have 224r cam with $1000 stg 2 heads and all bolt ons going about 12.0@115(398 rwhp)
have not gotten pulled by any z06's yet.(except for a 600rwhp supercharged z) still would be a little nervousl running a twin turbo.
[Modified by 1fastmfc5, 9:24 AM 4/13/2004]
Old Apr 13, 2004 | 07:40 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: Comp 220/220 or 224/224? (1fastmfc5)
the 224 will idle good, bottom end should not be effected.
you will need tuning to make it right. I wanted a daily driver
and i am glade i didn't get the 220 cam.
if you do heads later the 224 is as small as i would go.
Old Apr 13, 2004 | 07:46 AM
C5 CU's Avatar
C5 CU
know of several running the 228 cam (114*) and they really like it...great street manners and lots of good power...
Old Apr 13, 2004 | 08:18 AM
Blow Torch's Avatar
Blow Torch
Jerrivette
Not if one of those bolt ons is NITROUS!!!!
:D
Old Apr 13, 2004 | 08:34 AM
HITMAN99's Avatar
HITMAN99
Couple of thoughts. If you're concerned about loss of low-end power, you can always advance the cam two degrees. This will get your intake opening point closer to what the 220 cam has. If you want a bit more mid-range, get the cam on a 112 LSA vs a 114. It will idle a little rougher, and off-idle throttle response won't be as crisp, but the mid-range will be better.
To Comp 220/220 or 224/224?
Old Apr 13, 2004 | 08:51 AM
JerriVette's Avatar
JerriVette
Default Re: Comp 220/220 or 224/224? (HITMAN99)
I think a stock Z06 runs neck and neck with a Porsche 911 TT...so a c5 six speed with either a 220/220 114 or a 224/224 cam throwing down 390 hp should take out the TT..
As far as new heads..AFR seem to be the trick and the gentlemen who mentioned...the 224/224 as emissions legal for the sniffer test it would be as small as many tuners suggest for getting the most out of new Heads..(afr or otherwise)
No bottom end loss..with just these cams either..just a nice surge in the midrange..and upper end..
Totally civilized too....
Porsche is a great car but unless its a GT2 I wouldn't worry about it...especially if your running 12.4's @ 114mph...with a couple of bolt ons...
Sounds like you know how to drive well too..
Do the 224 cam and you'll take these guys out easily..
JMO
[Modified by JerriVette, 7:53 AM 4/13/2004]
Old Apr 13, 2004 | 10:47 AM
colbachlaw's Avatar
colbachlaw
Default Re: Comp 220/220 or 224/224? (JerriVette)
As far as the Porsche vs Vette thing goes, I forgot to mention I am driving a 2001 Z06.
I think a stock twin turbo is a low 12 second car (not that any of them ever show up at the track) and my Z is running 12.4x at 114 right now, so I am hoping a decent cam would at least make me even with the twin turbos.
With a set of AFR's and a decent cam I should be able to make 425 at the wheels, which should put me ahead of the turbo guys. If not, I can always bolt on an ATI blower.
Who sells the 228/228 or the 224/228? What is a good LSA on these cams for a daily driver?
Sorry for all of the questions, but I don't want to do this twice.
Thanks,
Mike
Portland, OR
Old Apr 13, 2004 | 10:56 AM
Shinobi'sZ's Avatar
Shinobi'sZ
I would go with the Comp Xer 224/224. I watched an 03 Z06 with this cam, headers, a vararam, and MT/ETs run 11.4 in the 1/4 last year....not to shabby. The cam is a great cam...I and Andy have been using it for sometime now.
