160 vs 172 thermostat
Old Apr 12, 2004 | 09:36 PM
Ebein's Avatar
Ebein
Default 160 vs 172 thermostat
Is there any reason you wouldnt want to run a 160 Thermostat vs a 172/175
thermostat?
Old Apr 12, 2004 | 10:52 PM
lost's Avatar
lost
Default Re: 160 vs 172 thermostat (Ebein)
Longer warm up time in winter with 160, in extreme cold you might freeze to death....
Old Apr 12, 2004 | 11:15 PM
SQEZN BI's Avatar
SQEZN BI
12 degrees. leave your stock stat, lower your fan settings. When your car is 190 the 160 is full open and the 172 is full open. Heat makes horsepower.
Old Apr 13, 2004 | 02:12 AM
LBear's Avatar
LBear
Default Re: 160 vs 172 thermostat (SQEZN BI)
Stock t-stat open at 192F. If you set your fans to turn on at 190F, the fans will be fighting the t-stat, not a good choice.
Heat does make power BUT to a certain degree. The LS1 makes the most power between 185-190F. Even temps of 195F are OK, but after that, the HP levels begin to drop.
This is a FACT. The reason the LS1 was set-up to run 230F was because OF EMISSIONS not because of HP. The hotter it gets, the cleaner in runs, EPA regulations needed to be met.
I recommend a 170F t-stat. Set the fans to 180F. THe car will run 20 degrees hotter than the t-stat opening point. So about 185-195F.
Old Apr 13, 2004 | 04:46 PM
FKING1's Avatar
FKING1
Default Re: 160 vs 172 thermostat (pettrix)
:iagree:
Right on!
Fred K.
Old Apr 13, 2004 | 04:49 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
LG installed a 160 for me... Being that I live in Texas and spend a lot of time on the autocross course, it seems like a good choice to me. I might change back to a stocker for the winter months, though. For now, she runs about 175 down the highway. :D
Old Apr 13, 2004 | 04:59 PM
lost's Avatar
lost
Default Re: 160 vs 172 thermostat (FKING1)
At 200 degrees my car is a slug, barely able to get out of its own way.I have two 13.95+ timeslips to prove it, I also have a 13.17 run at 178 degrees. Only changes to the car was the t=stat ,Hypertech programming and a ZO6 catback...
Old Apr 14, 2004 | 09:41 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: 160 vs 172 thermostat (lost)
i have a 172/178 stat in my car it still wants to run at 190-194min. (fans lowered) this is in 50-60 deg. air. on the dyno the car pulled 7 more hp at a lower temp's. I didn't want the 160 stat ether but a 160 is on order. I was told to expect 173 running temp with the 160.
i don't do much winter driving so low heater temps is not an issue for me.
Old Apr 14, 2004 | 10:42 AM
Slickk.'s Avatar
Slickk.
Default Re: 160 vs 172 thermostat (Mr. Jones)
:beatdeadhorse:
Old Apr 15, 2004 | 12:34 AM
VETFVER's Avatar
VETFVER
:iagree:
Old Apr 15, 2004 | 01:54 AM
Ebein's Avatar
Ebein
Default Re: 160 vs 172 thermostat (VETFVER)
Thanks for the input, sounds like 160 is overkill, and Ill look to get a 170.
Old Apr 15, 2004 | 02:22 AM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
172 stat for me...and workin like a charm...definitely keepin everything cooler...
Old Apr 15, 2004 | 10:51 PM
fascar's Avatar
fascar
I don't think you will notice any difference between 160 and 172 I have 160 stat and my 99 runs about 175 to 180 I have fans set to come on at 200 and off at 180
Old Apr 16, 2004 | 01:22 AM
LBear's Avatar
LBear
Default Re: 160 vs 172 thermostat (fascar)
There is a problem with running TOO COLD. THis needs to be addressed. The all aluminum LS1/LS6 can run hotter than an iron block/heads motor. Having it TOO COLD causes a HP loss, as does running TOO HOT, causes a HP loss.
There is a "sweet spot" for LS1 motors. Ask any dyno place and they will usually agree that it is the 185-195F range. Some may even say 200F but the average is 185-195F.
Running at temps below 180F makes the computer believe that the car has NOT warmed up to opertating temperature. So running TOO COLD has the same HP loss effect as running TOO HOT.
:seeya
Old Apr 16, 2004 | 07:31 AM
Mr. Jones's Avatar
Mr. Jones
i think the computer see's 163 as the maximum low temp. anything above that is good operation temp. a stock car may run cooler with a 178 but add some HP and my178 runs at 190-194 in cool air. i havn't driven it in hot weather with the present setup.
Old Apr 16, 2004 | 10:06 AM
6Speeder's Avatar
6Speeder
Running at temps below 180F makes the computer believe that the car has NOT warmed up to opertating temperature. :seeya
That's an oft quoted mistruth. The computer takes the engine out of cold loop and operates with the normal fuel/air maps at a MUCH lower temp than you will ever see with ANY available thermostat, someone will give real number, but I think it's below 120 degrees. The computer will adjust your oil life monitor as a function of cooler operation, giving less miles between oil changes if you run the engine cooler. With a 160 Stat, mine recommends oil changes at around 4.500 - 5.000 miles, which I would do anyway. :cool:
To 160 vs 172 thermostat
