Low coolant light
Old Apr 14, 2004 | 09:16 PM
ndared's Avatar
ndared
Default Low coolant light
My 97 has a habit of displaying "low coolant" on DIC. I've heard that 97's had a problem with sensor in the resivour. What is the fix ? Will a later model tank solve the problem ? vendor & pricing?
:confused:
Old Apr 15, 2004 | 01:03 AM
BlackMagicC5's Avatar
BlackMagicC5
Default Re: Low coolant light (ndared)
I had mine come on for the first time ever when I was sitting in traffic a few months ago. It stayed on for about 10 minutes, til I parked and shut it down. When I started it back up, all was fine. Haven't had it come back on since. I'm guessing the sensor set it off for no reason, because I hasn't come back on and I never even opened the tank. I hope mine isn't going.
:lurk:
Old Apr 27, 2004 | 05:04 PM
MG RED 99's Avatar
MG RED 99
Ran into the low coolant light problem when I swapped the coolant tank for a new painted to match coolant tank. Found out the problem was I was sent a newer style coolant tank which looks exactly the same as my 99 tank but the coolant float switch internal to the tank is different per model year of vehicle. The vendor where I purchased it from had no idea, but he ordered the correct model year tank and the problem was solved. Just wanted to save you the trouble of buying a later model tank that won't work for your specific year vehicle, because the coolant level switch will plug into both styles!
The only thing I can recommend is buying a new tank which isn't to expensive if youv'e determined it must be the switch inside the resevoiur.
Hope this helps!!
Old Apr 27, 2004 | 07:52 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Low coolant light (MG RED 99)
Quit parking pointing downhill, and add a cup or two of coolant. :D
I had the same thing parking nose-down at work.
To Low coolant light
