Headlight issue - intermittent operation
Old Apr 15, 2004 | 11:42 AM
The One's Avatar
The One
Default Headlight issue - intermittent operation
Got caught in a bad downpour a couple of weeks ago and when I tried to put the headlights on, they wouldn't come up. After I got home 40 minutes later they worked. This morning I tried them 5 or 6 times and they came up about 50% of the time. When they do work, both lamps come up. When they don't work, I DO NOT hear the motors trying to work. Almost seems like a short somewhere. :confused: Any ideas???
[Modified by The One, 11:11 AM 4/15/2004]
Old Apr 15, 2004 | 11:53 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Headlight issue - intermittent operation (The One)
1ST,make sure that the battery cables are snug :yesnod: The headlamp door module is very sensitive to voltage drop.If that does not fix it,you are looking at either a faulty headlamp module or the switch :cheers:
Old Apr 15, 2004 | 12:12 PM
The One's Avatar
The One
Default Re: Headlight issue - intermittent operation (C-5 TECH)
Thanks C-5 TECH! :cool: I'll look into those suggestions. :cheers:
To Headlight issue - intermittent operation
