Stainless steel pad covers..Install ????
Old Apr 15, 2004 | 09:05 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Stainless steel pad covers..Install ????
Is is better to grind the "nubs" off of the pad surface, or another solution?? I need feedback as I am getting ready to install my new rotors. Thanks! Greg
[Modified by 3Vettes@Home, 9:05 PM 4/15/2004]
Old Apr 15, 2004 | 09:24 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Stainless steel pad covers..Install ???? (3Vettes@Home)
Yes, you'll need to grind the nubs off the pads to fit them, as well as the soft shim that's glued on the back of the pad.
I think they also recommend a little bit of sealant (silicone rtv) between the pad and cover, but I didn't use anything and have had no noise or sqeak issues.
:cheers:
Old Apr 15, 2004 | 10:04 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: Stainless steel pad covers..Install ???? (Y2Kvert4me)
Thanks!...Your vette is FANTASTIC! :cheers:
Old Apr 16, 2004 | 10:07 AM
BayouVette's Avatar
BayouVette
Absolutely FANTASTIC..
if you have time when you install your covers maybe you could take some pictures and do a write up of the install. :D You would be the man..
I know it has been asked several times before for a how - to.
Old Apr 16, 2004 | 11:16 AM
Patches's Avatar
Patches
I ground the nubs off of mine and used a bit of sealant as recommended in the instructions. They've been perfect for 2 years. :cheers:
To Stainless steel pad covers..Install ????
