Oil pressure sensor
Old Apr 16, 2004 | 08:50 AM
Roy7s's Avatar
Roy7s
Cruising
Default Oil pressure sensor
Ok where do they hide the oil prssure sensor? :withstupid:
Old Apr 16, 2004 | 09:52 AM
birch64's Avatar
birch64
Default Re: Oil pressure sensor (Roy7s)
Remove the coil covers, the air bridge, and the wires connecting to the injectors..you do not have to disconnect the fuel line.. remove the bolts holding down the intake... lift and move forward about six inches... the sensor is located about an inch from center towards the drivers side... remove the connector .... ( make sure you cover the two open intake chambers with a towel so no dirt gets in there) ... you can reuse the intake gaskets.,..remove the sensor ( 1 1/8th socket ) ... put in the new one.... torque to 15 ft lbs. ......... intake bolt torque 1st pass 44 in. lbs., second pass 89 in. lbs. Also ( very important ) there is a 1/8 black vacuum hose which becomes disconnected when you move the intake forward.. it is located about two inches from center on the passengers side up under the window cowl.. it connects to a rubber "L" shaped connector almost in the rear center of the intake.. this vacuum line controls your A/c doors... there's is a picture of the sensor location in the tech's tips.... I hope this helps..
[Modified by birch64, 2:53 PM 4/16/2004]
Old Apr 16, 2004 | 12:07 PM
Roy7s's Avatar
Roy7s
Cruising
Default Re: Oil pressure sensor (birch64)
Thanks a lot i was going nuts trying to find it :smash:
Old Apr 16, 2004 | 03:34 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Welcome to the forum Roy7s
There is a tech tip section here , if you go to the top of this page then click on tools then tech tips, then C5, then look for a topic that addresses your issue... Some of us spend alot of time writing up these tech tips and posting pictures,etc... to try to help our fellow C5 members... Tech tips is aalways a good place to start.,.,, if nothing is in there just ask... someone has had your problem before you...
[Modified by Evil-Twin, 3:40 PM 4/16/2004]
To Oil pressure sensor
