HELP, ENGINE LIGHTS ON?
Old Apr 16, 2004 | 10:21 PM
babala65's Avatar
babala65
Default HELP, ENGINE LIGHTS ON?
I just got my car out for the first time yesturday after A winter mods 4:10 gear,X-pipe with gutted catts, O2 sims, 100 shot N2o, ele. cutouts, hyper tech power programer 2, and SLP inlet temp sensor, Vortex power inlet and ram air box, and MSD wires.
The car runs great with no other poblems But the light came on after about 15 mins.
:confused: :confused: :beatdeadhorse: :beatdeadhorse: :banghead: :banghead:
Old Apr 17, 2004 | 12:25 AM
jetning's Avatar
jetning
Default Re: HELP, ENGINE LIGHTS ON? (babala65)
what's the code showing?
Old Apr 17, 2004 | 12:37 AM
DsC5's Avatar
DsC5
Default Re: HELP, ENGINE LIGHTS ON? (pinoy vette)
:withstupid:
Old Apr 17, 2004 | 02:07 AM
babala65's Avatar
babala65
No code, just check eng. light???
Old Apr 17, 2004 | 02:18 AM
DsC5's Avatar
DsC5
Did you hold the option button and press fuel 4 times? And still no codes showing? :confused:
Old Apr 17, 2004 | 10:10 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If the check engine light is on, there will be a code. you'll have to go into the diagnostics to find it.
Old Apr 17, 2004 | 10:18 AM
mapman's Avatar
mapman
Default Re: HELP, ENGINE LIGHTS ON? (runamuk)
Try the link below. It is from the Forum "Tools" section.
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Apr 17, 2004 | 10:41 AM
babala65's Avatar
babala65
Default Re: HELP, ENGINE LIGHTS ON? (mapman)
Thanks, I will try that and see what happens!
Old Apr 17, 2004 | 11:55 AM
babala65's Avatar
babala65
Thats really A cool tool to have built in A car,
This is what it spit out 10-pcm po140 HC my code book says its HEATED OXYGEN SENSOR (HO2S) CIRCUIT INSUFFICIENT ACTIVITY BANK 1 SENSOR 2
Who knows what that means?
Old Apr 17, 2004 | 05:05 PM
babala65's Avatar
babala65
TTT :steering:
Old Apr 17, 2004 | 08:30 PM
dpd's Avatar
dpd
left rear o2 sensor.just saw you're running simms.check the simm connector,if it's ok,swap the simms left to right.if the fault moves to the other bank,the simm is puked.
[Modified by dpd, 1:36 AM 4/18/2004]
To HELP, ENGINE LIGHTS ON?
