Left Side Driver Light Out?
Old Apr 17, 2004 | 11:28 AM
Gipper's Avatar
Gipper
St. Jude Donor '12
Default Left Side Driver Light Out?
My left side exterior driver light went out a couple of weeks ago. I replaced it the other day and it tested ok after starting the car. Next day, it was back out!?!? I just got done poking around and tried another new bulb but no go? I checked the fuses and they all looked fine although I couldn't determine exactly which fuse is for the driver side "driver" light based on the cryptic diagram. Any ideas? The housing looks fine... :confused:
Old Apr 19, 2004 | 09:27 AM
Gipper's Avatar
Gipper
St. Jude Donor '12
Default Re: Left Side Driver Light Out? (Gipper)
ttt
Old Apr 19, 2004 | 09:32 AM
dahoof's Avatar
dahoof
Did it burn out? Have you tested it with a Voltmeter to see how much juice is running to it? Sounds like its grounding out somewhere. If it works initally then it would not be a fuse. Good luck! :cheers:
Old Apr 19, 2004 | 11:27 AM
Gipper's Avatar
Gipper
St. Jude Donor '12
Default Re: Left Side Driver Light Out? (dahoof)
first one burned out but the other 2 I put in did not burn out and looked fine "visually". Test with a meter? Now that would be a good trick since I can only get one arm in that cavity. :)
Also, my left turn signal is blinking twice as fast as normal. Is that by design when a bulb goes out or a sign of something else? thx.
To Left Side Driver Light Out?
