Lowering problem need help ASAP
Old Apr 26, 2004 | 10:54 PM
SQEZN BI's Avatar
SQEZN BI
Default Re: Lowering problem need help ASAP (speedracerchick1)
I cut the front bushings and lowered the front in less than an hour, there is no need to remove anything exept some of that rubber bushing. I jacked up the front then put another jack under leaf ,jacked leaf up to gain enough space to use a hacksaw blade . You have to come in from behind it and cut tward yourself, you only get a couple inches of blade used but if you go right on the indentation or seam it will cut perfectly straight just before the steel insert. sawing lightly doesn't work you have to push hard and once it starts cutting it only takes about 30 seconds. good luck
Old Apr 27, 2004 | 06:39 PM
speedracerchick1's Avatar
speedracerchick1
8th Gear
Default Re: Lowering problem need help ASAP (SQEZN BI)
we got it lower'd looks much better now..
[Modified by speedracerchick1, 11:40 PM 4/27/2004]
[Modified by speedracerchick1, 5:42 PM 4/27/2004]
