air pressure sensor
Old Apr 17, 2004 | 09:55 PM
racer959's Avatar
racer959
Default air pressure sensor
I am replacing my air pressure sensors on my 2002 ZO6, somebody told me that they have to be reprogrammed at the dealer, is this true, thanks for your help :confused: :cheers:
Old Apr 17, 2004 | 10:00 PM
orangecrrrush's Avatar
orangecrrrush
Default Re: air pressure sensor (racer959)
No... it is not true. All you need is a heavy duty magnet. Go into your DIC(driver info computer) and get it into a FOB training mode. If you skip the key fob training, the next is to learn the tire sensors. You would start with the left front. Put the magnet on or next to the valve. Your car will honk once it has programmed the tire sensor. Then move to the next tire and do the same thing. Repeat the steps for the rest of the tires and your wheel sensors will be programmed.
Good luck
Old Apr 18, 2004 | 12:01 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I'm sorry I'm not sure I understand the question.
Z06's don't come with TPS's. If you are adding TPS's to your Z06's wheels then you will have to go to the dealer to have them turned on. Then you can program them yourself.
Old Apr 18, 2004 | 01:56 PM
racer959's Avatar
racer959
Default Re: air pressure sensor (ROCKnROLL)
ROCKnROLL, are you sure ZO6's have no tire pressure sensors? I'm replacing my stock wheels to CCW wheels and I was going to buy sensors for the new wheels ( thinking they have sensors) and leave the stock ones alone, I do not want to put sensors if the stock ones do not have them, can somebody else help also, thanks :confused:
Old Apr 18, 2004 | 02:40 PM
RUBYREDVET's Avatar
RUBYREDVET
Z06 do not come with tire pressure sensors from the factory since Z06 doesn't use EMT tires. :cheers:
Old Apr 18, 2004 | 03:48 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Z06's do not come from the factory with TPS's.
If you bought the Z used it's possible the previous owner had the sensors installed. If you bought it new they're not there.
If you're getting tire pressure readings on the DIC then you do indeed have sensors but they were installed after the car was purchased.
To air pressure sensor
