Tranny ?
Old Apr 18, 2004 | 06:29 AM
RunNE1's Avatar
RunNE1
Default Tranny ?
Is the tranny fill plug, the 11 mm bolt on the left side of the tranny that is up towards the front about 2 inches above the pan?
On a A4 of course...
[Modified by RunNE1, 5:30 AM 4/18/2004]
Old Apr 18, 2004 | 07:01 AM
kirbyloid's Avatar
kirbyloid
Default Re: Tranny ? (RunNE1)
I would like confirmation of this?
I am looking at the Service Manual and the way I read it and looking at the picture the plug on the side of the pan is the Check/Fill and drain plug it is on the drivers side of the vehicle according to the Service Manual.
Old Apr 18, 2004 | 08:08 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Tranny ? (krl)
That is correct, it's the large plug on the left side of the pan.
Make sure the car is raised and level and the trans temp is between 86 - 122 degrees F, and the engine must be running with the trans in "P" before you pull this plug
Old Apr 18, 2004 | 09:59 PM
RunNE1's Avatar
RunNE1
Default Re: Tranny ? (runamuk)
Well the bolt that I am looking at is not really large. In fact, it is very small when compared to the drain pug. Do I have the wrong bolt.
Would you be able to post that diagram KRL ?
Old Apr 18, 2004 | 10:07 PM
blu00rdstr's Avatar
blu00rdstr
The plug is on the oil pan on the drivers' side towards the rear. The exhaust pipe is about 2" to the side. It requires a 21mm wrench. And it can be a bee-atch to fill right, took me three times to get it filled completely.
Old Apr 19, 2004 | 08:53 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Tranny ? (blu00rdstr)
:iagree:
If the bolt you are looking at is not in the side of the tranny pan then you are not looking at the right bolt, there is only 1 fill plug and it's in the tranny pan not on the side of the tranny case.
Old Apr 19, 2004 | 10:29 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:iagree: :iagree: :thumbs:
Old Apr 20, 2004 | 02:10 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Tranny ? (LittleBoyBlu99)
On the Left
[Modified by wallstAL, 11:11 PM 4/19/2004]
Old Apr 21, 2004 | 02:26 AM
RunNE1's Avatar
RunNE1
Default Re: Tranny ? (wallstAL)
Thanks for all the help guys, but it was all in vain. The bolt was stripped. When I put the box end of the 21mm wrench, all it did was finish it off. So now, the bolt is stuck. Is it hard to drop the pan? I was thinking of trying to drill it/ tap it out with the pan off, of course. Should I just wash my hands if it and send it to the shop? It does not look that difficult to drop the pan. I am worried about the refill/refilter procedure.
Thanks :cheers:
P.S. WallstAl, your tranny pan looks very different from mine. Is that an upgrade?
[Modified by RunNE1, 1:27 AM 4/21/2004]
Old Apr 22, 2004 | 02:32 AM
RunNE1's Avatar
RunNE1
Well the guys at LG Motorsports came through and saved the day. They were able to remove the plug fairly easily. Thanks to Shawn/Sean? for taking care of it so quickly. :cheers:
To Tranny ?
