Z06 cam installed in LS1
Old Apr 21, 2004 | 09:28 AM
cbota's Avatar
cbota
Default Z06 cam installed in LS1
Hi,
Just wanted to know if I install a 2002 Z06 cam in a 99 LS1 what needs to be changed. I understand that the springs need to be upgraded for the higher lift. But what about the pushrods, what is the stock size and do they need to be changed for the length or strength. :seeya Thanks
Old Apr 21, 2004 | 01:17 PM
Midwayman's Avatar
Midwayman
Default Re: Z06 cam installed in LS1 (cbota)
AFAIK the ls6 pushrods are identical to the ls1 pushrods. Plenty of people out there using stock pushrods on all sorts of cams.
Old Apr 21, 2004 | 02:06 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
If you're going to go through the effort of changing the cam, you might as well put a BIG one in there, don't you think? :jester
Old Apr 21, 2004 | 02:50 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Z06 cam installed in LS1 (Umrswimr)
Unless you are going to be putting a blower on I would go bigger. With the way the tuners have advanced the breed in the last couple of years you can get great power with near stock drivability -
Just don't forget to upgrade your springs they will be your next weak point in the valve train
[Modified by Ruby6spd, 4:24 PM 4/21/2004]
Old Apr 21, 2004 | 03:20 PM
SideStep's Avatar
SideStep
A C T U A L L Y....
The pushrods are a different length, but many of the sponsoring tuners on the forum just use the factory LS1 pushrods and let the lifters take the difference.
The LS6/ZO6 cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves.
Here is a link to SDPC with a little more info... If you are **** about the details they (SDPC) can sale you a set of 7.450" LS1 Manley Pushrods that would make the difference...
http://www.sdpc2000.com/cart.asp?act...1981&pid=81649
Good Luck,
:cheers:
[Modified by SideStep, 3:46 PM 4/21/2004]
Old Apr 21, 2004 | 04:31 PM
Midwayman's Avatar
Midwayman
Default Re: Z06 cam installed in LS1 (SideStep)
That link you posted says that the Valves are different length on the ls6, not the pushrods. Just that when using a ls6 cam in a ls1 head, you need different pushrods to make up the difference in valve length.
It seems to imply that the ls6 pushrods are the same length.
Anyhow, Im not expert, just repeating what Ive heard before on here.
Old Apr 21, 2004 | 05:25 PM
cbota's Avatar
cbota
Thanks guys for the input, from what Ive been reading it looks like the the 7.4 PR are a little short but the 7.45 are a little long, and short is better than long? :crazy: :crazy:
Old Apr 21, 2004 | 05:42 PM
SideStep's Avatar
SideStep
The majority use the factory pushrod... Head over to http://www.ls1tech.com/forums/ Much more info over there...
:cheers:
Old Apr 21, 2004 | 06:26 PM
SFVetteman's Avatar
SFVetteman
The 2002 LS6 pushrods are the same length as the LS1 pushrobs but as noted the 2002 LS6 valves are longer to make up the difference of the 0.050 smaller base circle of the 2002 LS6 cam. Use of pushrods that are 0.050 longer should position the lifter in the same spot as stock with LS1 length valves.
When you add the cost of the new pushrods to the cost of the 2002 LS6 cam you are pretty close to the price of most aftermarket cams. Why not just go with a mild aftermarket cam and get more performance than the 2002 LS6 cam for about the same money :confused:
Old Apr 21, 2004 | 06:43 PM
cbota's Avatar
cbota
Default Re: Z06 cam installed in LS1 (SFVetteman)
The cam shaft is .05 smaller but I think that is only .025 on each side, so if the PR are .05 larger that would be .025 to long. :beatdeadhorse:
Old Apr 22, 2004 | 09:43 PM
Buzz1's Avatar
Buzz1
I think i still have the push rods for the ZO6 cam if you need them,Buzz
Old Apr 23, 2004 | 06:35 PM
cbota's Avatar
cbota
Default Re: Z06 cam installed in LS1 (Buzz1)
Can someone let me know if the LS6 and LS1 pushrods are the same. Thanks :seeya
Old Apr 28, 2004 | 12:41 AM
mjb929rr's Avatar
mjb929rr
Check dyno sheets out in sig. My car dynoed 352rwhp with only a ls6 cam, slp lm, and twinflow intake, There is a comparison that we did of an 03 6sp and it dynoed 307 so for the money its not a bad choice. I was lucky that my car already came with it in. If money was no option then go bigger but this small cam will let you run with a z06 without a problem.
Old Apr 28, 2004 | 07:06 AM
cbota's Avatar
cbota
Default Re: Z06 cam installed in LS1 (mjb929rr)
Now that's what I like to see, 352 RWHP without headers and upgraded heads :hurray: I would be happy with those numbers, Good job :D
To Z06 cam installed in LS1
