Great time at ED WRIGHTS getting dyno tuned
Apr 21, 2004 | 12:22 PM
Well ED picked me up some HP and TQ and made my driveablity 200% better on my 418 stroker motor.
Apr 21, 2004 | 12:33 PM
St. Jude Donor '05
Re: Great time at ED WRIGHTS getting dyno tuned (Iboomalot)
Great, I have not heard his name in a long time! How much did you pick up?
Apr 21, 2004 | 12:45 PM
Re: Great time at ED WRIGHTS getting dyno tuned (wallstAL)
find out at 3:00 pm when I get it dynoed locally
Apr 22, 2004 | 12:17 PM
Just looked at your sginature. I see you have the fast 90mm setup. How much did you gain from that setup?
Apr 22, 2004 | 04:29 PM
Re: Great time at ED WRIGHTS getting dyno tuned (Corvette4ever)
:lurk:
Apr 22, 2004 | 06:02 PM
Do you have the SAE Corrected numbers? STD is usually higher. I believe everyone goes by the SAE standard around here. Nice numbers tho. :cheers:
[Modified by RoliO, 5:02 PM 4/22/2004]
Apr 22, 2004 | 07:04 PM
Re: Great time at ED WRIGHTS getting dyno tuned (RoliO)
picked up like 10-12 hp with FAST not as much as possible.
two things could be holding back topend power
heads and springs
using a 918 spring might go to something stiffer
also might goto a AFR 225cc head soon too.
I did pick up more torque from 3200 - 4000 then more HP from 5400 - 6400 rpm
getting tired of coming up short of 500 rhp might say this is good enough.
Apr 23, 2004 | 01:03 PM
Cruise-In V Veteran
St. Jude Donor '09
Did Ed lock your PCM???
Apr 24, 2004 | 12:19 AM
How long did it take Ed to tune your Fast 90mm combo?
Apr 24, 2004 | 09:37 AM
Cruise-In V Veteran
St. Jude Donor '04
Re: Great time at ED WRIGHTS getting dyno tuned (Bink)
Ed locks all of the PCM's he programs, but do you really think he's the only one that does this
Apr 24, 2004 | 11:28 PM
Re: Great time at ED WRIGHTS getting dyno tuned (runamuk)
not sure if he locked it or not I don't think so.
took him about 4 hours and 6-8 dyno runs.
1/2 of that was redoing the tuning that was done before I got there.
my torque sure goes up fast & then drops fast vs other peoples graphs i've looked at.
whats your opinions on that?? loosing air due to being LS1 heads??
