Well new motor should be coming in in about a week or two and then i will take to lapd to have it tuned how much power do you guys think it will make. I am hoping for at least 450-460 to the ground.
Polished & Magnafluxed Stock Crank 3.622" stroke crank
compression ratio 11.5:1
Diamond Forged Pistons / Flat Tops
Diamond 4130 Chromemoly Wrist Pins
Diamond Pro Select Ring Set/ File Fit
Eagle H-Beam Connecting Rods
Federal Mogul 152M Main Bearings
Clevite CB663H Connecting Rod Bearings
Clevite LS1 cam bearings
ARP Main Studs
Cam is 238/242 605/609 on a 112 lsa
TSP Race heads 59cc
LS6 intake
Vararam
Pulley
dynatech headers
with cats but will probably remove after :reddevil
30# SVO injectors
Aluminum flywheel
4.10's
comp r's
yella terra rockers
b&b bullets :reddevil
If you advance your cam 4* it will increase your dynamic compression considerably ( intake valve will close sooner)- does it say to advance it on the cam card??
My guess is 470 RWHP. You'll lose a little due to the 4.10s.
