DIC Codes...........HELP!!
Old Apr 24, 2004 | 10:54 PM
z28plus's Avatar
z28plus
Default DIC Codes...........HELP!!
I am getting these DIC codes..............C1221, and C1222, and an active handling warm up message that doesn't go away. The Orange active handling light stays on too.
:steering:
Old Apr 24, 2004 | 11:10 PM
Racin Z06's Avatar
Racin Z06
Default Re: DIC Codes...........HELP!! (z28plus)
C1221 and C1222 Left and Right front wheel speed sensors. Signal is 0. Turn on the ignition, but don't start it. Press and hold the "options" button. While holding the "options" button, press the "fuel" button 4 times. The codes will come up in the form of numbers. Hold the "reset" button and the codes will disappear. This doesn't fix the problem, but will turn off the light. If a bigger problem exists the light will come back on.
I hope this helps?
Old Apr 24, 2004 | 11:20 PM
z28plus's Avatar
z28plus
Default Re: DIC Codes...........HELP!! (Racin Z06)
thank you, I have done that and It does come back...........Can you tell what needs to be replaced?
Old Apr 25, 2004 | 02:41 PM
Nates99ss's Avatar
Nates99ss
Ive got a thread going right now, and a board member told me to pull my codes from the DIC (if there are any) HOW do I do this? TIA.
Old Apr 26, 2004 | 05:07 PM
z28plus's Avatar
z28plus
Default Re: DIC Codes...........HELP!! (Nates99ss)
ttt
To DIC Codes...........HELP!!
