FOR MY C5/1999 LS1 COUPE I WOULD LIKE TO FIT THE BMR SWAY BARS KIT (32MM FRONT-21 MM REAR):HAS SOMEONE EXPERIENCE ABOUT?
IN THE MARKET ARE ALSO AVAILABLE :
DRM,HOTCHIKINS,ADECCO...ANY SUGGESTIONS?
FOLLOWING MOD, ALREADY MADE:
STOPTECH BRAKES KIT (4 SLOTTED ROTORS-HPS PADS+S/S BRAKE LINES)
BMC AIRFILTER CARBON INTAKE
B&B HEADERS
REMUS S/S EXHAUST
HYPERTECH III + TERMOSTAT 160
PIRELLI PZERO TYRES
I have them they are a little heavy but I noticed a difference from my Z51 i also changed to 04 Z06 shocks when i did it too. I got the sway bars from Texas Speed.
You might even want to consider Z06 front and rear sway bars. They might be cheaper then the BMR's. The only thing you need beside the bars are new bushings. I have that I my car and I noticed a difference in handling when I switched bars. :cheers:
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Re: Sway bars (bassotto)
I would suggest the Z06 bars for most applications. I'm running them and love them for street autoX duty. Anything stiffer tends to get rough on the street. :cheers:
