Just got my Kooks headers........
Old Apr 27, 2004 | 09:51 AM
ragtopws6's Avatar
ragtopws6
Default Just got my Kooks headers........
Anybody know the torque specs on the header bolts? Do you use lock tight or anti-seize?
Old Apr 27, 2004 | 01:26 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: Just got my Kooks headers........ (ragtopws6)
Definately antisieze: never use Loctite for exhaust manifold or header bolts. I think the torque spec is 16 or 18 ft. lbs. In practice, it would be very difficult if not impossible to get a torque wrench on every bolt. So, you really have to tighten them by educated feel. If you use a 3/8" drive ratchet, you really have to be carefull how hard you pull as you really do not want to strip out the threads in the head or twist off the bolt head. The safe way is to use a 1/4" drive ratchet: if you tighten so much that the smaller handle is starting to hurt your hands, you are tight enough. :cheers:
Old Apr 27, 2004 | 01:46 PM
henchmen3's Avatar
henchmen3
Default Re: Just got my Kooks headers........ (2kbluestreak)
Get the motor nice and hot and re-tighten the bolts again. Be carefull not to burn your hands, but this will help alot.
Old Apr 27, 2004 | 01:50 PM
ragtopws6's Avatar
ragtopws6
Default Re: Just got my Kooks headers........ (henchmen3)
Yeh, found the specs on the header bolts. 11 FT LBS first pass, 18FT LBS final pass. Anti-seize only. Thanks guys for the info.
Old Apr 28, 2004 | 02:45 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
I hope to get my KooKS soon". :mad :cry :banghead: :D :seeya
Old Apr 28, 2004 | 10:30 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Default Re: Just got my Kooks headers........ (LittleBoyBlu99)
Got mine yesterday...shouldn't be long!! :cheers:
To Just got my Kooks headers........
