LS1 intake manifold vs. LS6
Old Apr 27, 2004 | 11:38 AM
Horseshoe Dozer's Avatar
Horseshoe Dozer
Default LS1 intake manifold vs. LS6
Thinking about my next mod and considering going from the LS1 intake manifold to the LS6 (also changing out the throttle body while I'm at it). Is it worth the cost?
Old Apr 27, 2004 | 12:17 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: LS1 intake manifold vs. LS6 (Horseshoe Dozer)
What other mods do you have?
Old Apr 27, 2004 | 12:23 PM
C5XTASY's Avatar
C5XTASY
For what it's worth, I was told, by a well-known tuner, that a switch to either the LS6, or FAST, intake manifold won't do much of anything on a basically stock, stock cubed motor. Now if you're planning on some serious modding down the line...
Ed
Old Apr 27, 2004 | 12:30 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
you better do a cam with that otherwise its a worthless mod by itself
Old Apr 27, 2004 | 12:34 PM
Horseshoe Dozer
Default Re: LS1 intake manifold vs. LS6 (Umrswimr)
Currently have Corsa Indy exhaust with x-pipe, Vortex Ram air induction system, WCC power duct, and Granitelli MAF.
Old Apr 27, 2004 | 12:47 PM
ArKay99's Avatar
ArKay99
I checked your profile and you have a 2003 C5. You already have an LS6 intake manifold on your car. You don't need to do this mod. Save up for a set of good LT headers. That will get you a good 20-25rwhp or more. :)
[Modified by ArKay99, 12:50 PM 4/27/2004]
Old Apr 27, 2004 | 12:51 PM
Mirek's Avatar
Mirek
Default Re: LS1 intake manifold vs. LS6 (ArKay99)
Does anyone know who sells JUST the coolant pipe and block off bolts required ?
Old Apr 27, 2004 | 01:04 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
If you are driving a 2003, you already have the LS6 intake.
Old Apr 29, 2004 | 02:34 PM
George8211's Avatar
George8211
Default Re: LS1 intake manifold vs. LS6 (REBEL03)
:withstupid:
Old Apr 29, 2004 | 03:12 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
In 2001 ALL the manifolds are the same....LS1/LS6................
Old Apr 29, 2004 | 03:13 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Your 2003 has the most current manifold........................
Old Apr 29, 2004 | 05:38 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
You should have had the 85mm MAF as well I hope you didn't throw it away it is 10 times the MAF the pos granny is---
Old Apr 29, 2004 | 07:44 PM
Horseshoe Dozer
Default Re: LS1 intake manifold vs. LS6 (NEPTUNEBILL)
Neptune............It came as a package deal with the Vortex Cold air induction system and it is the granny that is tuned for cold air (not the standard one). Seems to work much better than the stock maf for this setup.
Old Apr 30, 2004 | 09:17 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
dont you love it when the new guy spend 45,000 on a car, and dont know what they have in it.... Ahhhhhhhh the good old days !! :lolg: :lolg:
Old May 1, 2004 | 12:55 AM
blackjack's Avatar
blackjack
Default Re: LS1 intake manifold vs. LS6 (phils C5 vette)
Granny MAF slowed me down. It's for sale though. :hat
Old May 1, 2004 | 12:58 AM
George8211's Avatar
George8211
That's sooo mean :lolg: :lolg:
To LS1 intake manifold vs. LS6
