Anyone have the wiring schematic for '99 front end....
SOMEBODY's got to have a manual!
I'm still trying to gt the front end back together since the curb incident... all structural work is done but some wiring was ripped...horn, fans, foglites etc, and cant tell what connects to what :confused: Could someone post the manual's schematic to help me..thanks in advance. :flag
Re: Anyone have the wiring schematic for '99 front end.... (jawsski)
I have a Service Manual but there isn't a single schematic showing these items. Each item has its own schematic and section and the sections are scattered across at least two different books. The horn has one green and one black wire going to its connector. The green wire goes back to the underhood electrical center at A9 C3. The black wire goes back to ground at the Ground Distribution Cell 14 in Splice Pack #100. Splice pack 100 is located in the forward lamp harness attached to G102 which is located at the rear of the RH wheelhouse, between the battery and the Under hood electrical center.
The fog lamps have purple wires going back to the underhood electrical system at C1 and C3 and go to ground at the same point as the horns.
The left hand fan has a light blue wire going from B3 C3 of the underhood elec center and a black wire going to D10 C3 of the UEC. The right hand fan has a white wire going from E10 C3 of the UEC and a black wire going to G102.
I don't have any place to post pictures so that is about the best I can do.
Re: Anyone have the wiring schematic for '99 front end.... (jawski)
Bill, great help, thanks But could check for me the wiring harness on drivers side that has the purple wire for the fog lites. There is a red wire, black wire and pink with black stripe that appears to have been pulled from a connector. Is this the amber turn signal/running light wires?
Re: Anyone have the wiring schematic for '99 front end.... (kewlbrz)
Shawn, thank you:flag , that's everything up front....seems though that the pink/white I:yesnod: have doesn't match any of the schematic coloring:confused: . Perhaps a change was made some where on the production line :shocked:
Anyhow, its only one wire left; what can go wrong?
