Help! Low idle, stalls when in drive.
Old Apr 28, 2004 | 08:35 AM
ivandrea's Avatar
ivandrea
Default Help! Low idle, stalls when in drive.
Just finished installing bolt ons. Here's what I did. BBK 80mm Tbody, Vararam, Tbody bypass tube. Followed all the directions. After I let the car idle to operating temps I drove arounf the block. At no throttle the idle would creep to 2-300 rpms then shut off. What shoul I do to get a better idle?
Old Apr 28, 2004 | 08:46 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Help! Low idle, stalls when in drive. (ivandrea)
I'm sure the PCM is all confused with all the new air.........May need a tune or idle re-learn possibly.......
Old Apr 28, 2004 | 08:48 AM
simplyred02's Avatar
simplyred02
GM says to let the car idle for 10min, a/c off to relearn the idle. I would disconnect the battery for a few minutes and then try the relearn procedure
Old Apr 28, 2004 | 12:00 PM
carpe dm's Avatar
carpe dm
Default Re: Help! Low idle, stalls when in drive. (simplyred02)
:iagree: :yesnod: :)
To Help! Low idle, stalls when in drive.
