Cam choice
Old Apr 28, 2004 | 12:59 PM
Heretic's Avatar
Heretic
Default Cam choice
For a M6 car with LS6 heads and long tubes (probably Dynatechs)
I want low and mid range mostly, increase in average HP rather than peak.
TSPs 225?
Old Apr 28, 2004 | 01:00 PM
C5 CU's Avatar
C5 CU
Default Re: Cam choice (Heretic)
good results from the 228...
Old Apr 28, 2004 | 01:09 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Re: Cam choice (C5 CU)
I've read that the 224 is a good power adder...and I'll be finding out in the next couple weeks :thumbs:
:cheers:
Old Apr 28, 2004 | 02:49 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Cam choice (99SilverC5Coupe)
I'd go with a Futral 228. They use Cam Motion Lobes not a Comp grind. My #s are in my sig. :cool:
Old Apr 28, 2004 | 03:58 PM
Heretic's Avatar
Heretic
Default Re: Cam choice (93Polo)
I did forget to mention that Colorado has smog tests. IM240, to be exact. I think that 228 would be the largest duration that could be passed with stock cats, with the cooler metallic ones, I'd guess the 225 would be the most.
Does Futral have a grind in the 224-225 range? Their website leaves some to be desired, and I can't call them as I am at work right now.
I'd be temped to say screw it, and go with the G5X3, but I would hate to have to swap cams at smog time.
Old Apr 28, 2004 | 04:19 PM
Joe Vinci's Avatar
Joe Vinci
We have a large assortment of camshafts for each individual need. We have them for drag racing, street/strip, autocross, etc. Our cams use what we call accelerated lobe lift. Here is a link to our list of cams, and we can also do custom grinds. http://www.vincihighperformance.com/...AGE%20LS1.HTML Any questions, please give us a call.
To Cam choice
