battery drain
Old Apr 28, 2004 | 07:56 PM
davette's Avatar
davette
Default battery drain
I've been trying to track down a battery drain issue. My battery only seems to last about a week before it needs charging, if I don't drive it.
I bought a digital meter that displays MAamps. Normal discharge is supposedly under 50ma. My meter reads 02.31ma
That pretty good...right? If I am reading the meter correctly???? :confused:
Thanks!
Old Apr 28, 2004 | 07:59 PM
tpocock's Avatar
tpocock
Default Re: battery drain (davette)
That is correct. So your battery drain is not from anything outside the battery.
However, as a battery starts to fail it can develop an internal drain due to a short in the plates and you will not be able to measure this from outside of the battery. It can also fail to hold a charge, which will look the same as an internal drain. The only thing to do is to place the battery on the charger regularly until it completely dies, or replace it.
Old Apr 28, 2004 | 11:18 PM
BHP's Avatar
BHP
Mine reads 60 mA in sleep mode. The 02.31 mA sounds like 231 mA which would explain the drain.
Old Apr 29, 2004 | 10:49 AM
carpe dm's Avatar
carpe dm
Default Re: battery drain (BHP)
:iagree: Sounds likely. Has your battery ever truely discharged and needed to be re-charged? Sometimes they do not respond well to charging, so it could be a bad battery. Get a Battery Tender to use when the car is out of service for awhile. :)
To battery drain
