59cc heads??
Old Apr 28, 2004 | 10:28 PM
Fastbasser's Avatar
Fastbasser
Default 59cc heads??
What is the compression ratio with 59cc heads and a stock bottom end? Is 92 octane OK?
Thanks in advance..
:steering:
Old Apr 29, 2004 | 06:27 AM
Fastbasser's Avatar
Fastbasser
Default Re: 59cc heads?? (Fastbasser)
ttt
:steering:
Old Apr 29, 2004 | 08:04 AM
rwj383's Avatar
rwj383
11.13:1 with .056 gasket. While your cam profile makes a big difference in how your static cr and pump gas will work, If you have a PCM tuning program, you can make these heads work fine.
Robert http://www.gen3motorsports.com
Old Apr 29, 2004 | 08:31 AM
SvenOdin's Avatar
SvenOdin
Default Re: 59cc heads?? (rwj383)
My MTI Stg. II LS6 heads had been milled to 59cc. LGM did a little work on them and I haven't had a problem. I use 93 octange.
To 59cc heads??
