oil leak!
Old May 1, 2004 | 05:53 PM
myblackC5's Avatar
myblackC5
Default oil leak!
just noticed a oil leak under my car. coming from the front of the trans, it's a4. don't look like tranny fluid!
:banghead:
Old May 1, 2004 | 06:42 PM
Yibbutkeen's Avatar
Yibbutkeen
Default Re: oil leak! (myblackC5)
rear main seal?
I've yet to see or hear of a small block chevy that doesn't eventually leak there.
I'm not familiar with the c5 motors, but all the previous cars I've had with that block have leaked there.
Old May 2, 2004 | 10:26 AM
carpe dm's Avatar
carpe dm
What color is the fluid? Clean it well and check it periodically to try and tracee it down. In that location it just about has to be a trans seal. :rolleyes: :confused:
Old May 2, 2004 | 01:33 PM
simplyred02's Avatar
simplyred02
Since the trans is in the rear of the car you can probably rule out engine oil as a leak. Clean the excessive fluid really thorough with something like brake clean drive the car about 10mi. and recheck the leak. Possibly as simple as the pan gasket but could be the front pump seal.
To oil leak!
