URGENT HELP with cd changer/ipod connection
Old May 1, 2004 | 08:14 PM
tt_vette's Avatar
tt_vette
Default URGENT HELP with cd changer/ipod connection
I have all the required cables but I cannot figure out where to connect cd changer cable (CORHAR). I guess there are couple of different combinations, thanks to GM. It is a very sad case!! :nonod:
Old May 1, 2004 | 08:36 PM
mdhmi's Avatar
mdhmi
Default Re: URGENT HELP with cd changer/ipod connection (tt_vette)
You might have better luck posting in the Audio forum:
Click 'Forums' --> 'General Corvette Topics' --> 'Audio/Electronics'
Mark
Old May 1, 2004 | 09:09 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
The big connector on your CORHAR connects to your GM10-AUX. The small connector connects to a connector that was tucked under in the lower right hand corner of the fuse compartment in the passenger side foot well.
I have an iPOD in my Z06, hang in there, it really is nice.
:cheers:
Old May 1, 2004 | 09:36 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: URGENT HELP with cd changer/ipod connection (JimBacus)
If I rember correctly, the CD changer harness connects to two plugs in the passenger footwell access area. One connector is easy to find, the other is under the carpeting - taped to another wiring harness (yellow tape I believe); and a bitch to get to.
At the bottom of the footwell access cavity; pull up on the carpeting at the bottom of the opening and look backwards underneath the carpeting - towars the rear of the car.
BTW, Jim... that's some nice sailplanes you have. :yesnod:
[Modified by Mike Mercury, 9:39 PM 5/1/2004]
Old May 1, 2004 | 09:44 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Default Re: URGENT HELP with cd changer/ipod connection (Mike Mercury)
Mike is correct, it is two small connectors and one is quite hidden.
Here is a few pictures that I just went out and snapped that may help you out a bit.
The appropriate finger is pointing to the hidden cable, I had to dig it out from underneath the carpeting in the lower corner. The other connector is attached to the side of the fuse box with some sort of fastener.
HINT: if it doesn't work the first time you get it all together, pull apart and clean the connectors and reconnect, I think they got dirty over time.
You will like this mod when you get it all working, it will
Old May 1, 2004 | 09:46 PM
tt_vette's Avatar
tt_vette
Thanks alot Jim. I am running out now to find that sucker. :hurray:
Old May 1, 2004 | 10:41 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Thanks, those are the other composite ships that I pilot, besides the Corvette. :yesnod: I end up soaring in Ohio contests more than you might imagine, makes for a nice road trip.
To URGENT HELP with cd changer/ipod connection
