TNT wiring problem....
Old May 1, 2004 | 08:25 PM
Phil97SVT's Avatar
Phil97SVT
Default TNT wiring problem....
Its been some time since I used my nitrous. For some reason the system isn't working correctly. Here's what I have:
NX switch panel ->
NX Window switch 3000 | 6900
NX TPS Switch
TNT F1
Here's what I know....
1) The switch panel is getting power at all points
2) The rear bottle warmer works
3) The Window switch has power at its + and -
4) The TPS switch has power and lights under WOT
5) Switching the relays show both work
6) The solenoids can be operated manually
7) The Window switch output is showing a change is circuit @ 3k+
Test light lights when clip is on +
8) The TPS switch output is showing a change is circuit @ WOT
Test light lights when clip is on -
[Modified by Phil97SVT, 7:26 PM 5/1/2004]
[Modified by Phil97SVT, 7:27 PM 5/1/2004]
[Modified by Phil97SVT, 8:38 PM 5/1/2004]
Old May 2, 2004 | 08:43 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: TNT wiring problem.... (Phil97SVT)
NX switch panel ->
NX TPS Switch
TNT F1
You mean 12 volts at the + and ground connection is good?
Are you manually connecting 12 volts to test?
Is there a fuel pressure switch as well? How about bottle pressure and inline nitrous filter clog? Just some guesses. Also try replacing the window switch with a toggle switch just for testing.
