Need Cooler pipe fitting Help
Old May 2, 2004 | 03:03 PM
kirbyloid's Avatar
kirbyloid
Default Need Cooler pipe fitting Help
Can anyone tell me the type of fitting that screws into the top of the raidiator for the transmission cooler line. Went by NAPA and they do not know want to make up a custom stainless line but do not want to cut old one off for additional cooler rather than cut hose.
Thanks, kirby
[Modified by krl, 3:06 PM 5/2/2004]
Old May 2, 2004 | 03:26 PM
Miaugi's Avatar
Miaugi
Default Re: Need Cooler pipe fitting Help (krl)
:lurk: I could use that info as well please.
Old May 2, 2004 | 04:28 PM
SFVetteman's Avatar
SFVetteman
The transmission lines use 5/8-18, inverted flare type fittings.
The fittings are most commonly used in fuel systems and the inverted flare female fittings can be even harder to find than the male. I used an inverted flare female union to connect to male inverted flare that I put on the return line from the cooler to the return line to the transmission. The C5 uses a female union to join the two-piece transmission lines together and is GM #442338 :cheers:
Old May 2, 2004 | 04:53 PM
kirbyloid's Avatar
kirbyloid
Default Re: Need Cooler pipe fitting Help (SFVetteman)
Thanks for the help sent you an email with further clarification.
krl
Old May 2, 2004 | 05:00 PM
SFVetteman's Avatar
SFVetteman
The email address in my profile is my work email. Try billpar@netwiz.net as I will not be at work until tomorrow afternoon.
Old May 2, 2004 | 07:18 PM
kirbyloid's Avatar
kirbyloid
Sent an email to the above address as well.
krl
To Need Cooler pipe fitting Help
